SLI Bridge Not Detected
Go to solution Solved by Wander Away,
https://github.com/EmberVulpix/DifferentSLIAuto
Well this is somewhat of a fix, the only downside is the annoying "test mode" on the bottom right of the screens.
I'll get my hands on some light colored desktop background to cover it up then i guess.
It looks like a problem in the nvidia drivers for cards from different brands. It looks like this has been going on for a while as well, so probably not gonna get fixed by nvidia any time soon.
EDIT: http://puu.sh/icTin/4c0d16baef.jpg
Notice the semi-annoying test mode at the bottom right corner of each screen
Welp, to begin with, here's my system information (The important bit):
MB: Asus Gryphon Z97
CPU: i5-4690K
GPU: Zotac GTX 970
         MSI GTX 970 Gaming 4G
PSU: EVGA SuperNova 850 B2
Dual Boot windows 8.1 and 7
The Problem:
http://puu.sh/icQtc/d911be061a.png
Each card works individually, and both of them are recognized by the system.
What I've tried (For both my OS):
Swapping slots for each card;
different sli cables
plugging two sli cables into two fingers (hmmm)
Clean install of driver
BIOS update
googled a tool called DifferentSLIAuto1.2, while partially solving the problem, made the system a bit weird and booting into test mode. after disabling test mode, problem came back.
So, here I am, on the LTT forums screaming for help :c
Me: Computer Engineer. Geek. Nerd.
[Educational] Computer Architecture: Computer Memory Hierarchy
[Educational] Computer Architecture:  What is SSE/AVX? (SIMD)
https://linustechtips.com/topic/380564-sli-bridge-not-detected/
Do you have another system by any chance to put them both into?
https://linustechtips.com/topic/380564-sli-bridge-not-detected/#findComment-5141701
As far as I know there is a lot of issues with the Gryphon boards and SLI enabling.
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
https://linustechtips.com/topic/380564-sli-bridge-not-detected/#findComment-5141703
That board unfortunately does not support SLI
https://linustechtips.com/topic/380564-sli-bridge-not-detected/#findComment-5141724
Well, that's a problem. I'll google some more on that.
P.S. OSU! ADD ME! http://osu.ppy.sh/u/2262187
https://linustechtips.com/topic/380564-sli-bridge-not-detected/#findComment-5141730
Yeah not many people have had luck with SLI on them as far as I know I don't its even validated for SLI support which might be the issue your running into
P.S. Added in osu!
https://osu.ppy.sh/u/5223183
|King Of The Lost|
https://linustechtips.com/topic/380564-sli-bridge-not-detected/#findComment-5141772
-SNIP-
It's definitely validated for SLI... Oh well, not the first issue I've had with this board.
https://linustechtips.com/topic/380564-sli-bridge-not-detected/#findComment-5141906
https://linustechtips.com/topic/380564-sli-bridge-not-detected/#findComment-5141970
I would go crazy seeing that, I get annoyed by seeing it in windows 10 on my laptop still.
|King Of The Lost|
https://linustechtips.com/topic/380564-sli-bridge-not-detected/#findComment-5142122
For some reason, the windows 10 preview thing isnt bothering me too much on my laptop.
But its a super light blue color as wallpaper, so I can't really see it unless I try really hard.
https://linustechtips.com/topic/380564-sli-bridge-not-detected/#findComment-5142258
