Case mod ground questions
Solved by Matt420740,
That is technically an earth connection, not a ground. The point of an earth connection is if something inside the case shorts out, and applies voltage to the case itself, it will take the path of least resistance and travel down the earth connection instead of shocking whatever is in contact with the case. Its just a safety feature. Since you aren't going to get shocked by a wooden case, it would be okay to leave it unhooked.
Your board, HDD, etc. all get their DC ground from the PSU, not the earth connection, so it will still work fine.
