USB Sound Card
Go to solution Solved by BoredErica,
Sorry I'm still kinda new to the fourms
I'll help you out by chipping in with the answer, the answer is no, you likely do not need a sound card. But even if you did, we wouldn't know because you've given us next to no information. Information like what motherboard you use and what headphones you are using, and whether you are hearing problems with your audio.
Don't need one and a $30 dollar one would suck.
Intel Core i7 7770K | 32 GB's Ram 3000MHz | GTX 1080 Ti | 250GB SSD | 3TB 7400 RPM | Sound Blaster Z | ASUS ROG MG278Q | Razer Blackwidow Chroma | Final Mouse 2015 | Blue Yeti | Seinheiser HD 600's | Beyerdynamic DT 990 Pro | Aune T1 MK2
https://linustechtips.com/topic/373948-usb-sound-card/#findComment-5058378
We're going to need a little more information before we can tell you if you need one.
N64 HTPC: [Completed]
Main PC: i7 4770k @ 4.2 Ghz | Be Quiet! Dark Rock TF | Asus Z87 Maximus VI Formula | G Skill Ripjaws X 16GB | Zotac GTX 1070 | Samsung 850 EVO 500GB | Seagate 1TB Hybrid | Samsung 840 EVO 128GB | Corsair 1200i | Thermaltake Core P5
https://linustechtips.com/topic/373948-usb-sound-card/#findComment-5058383
Do you need to check if your thread has been posted a hundred plus times in this subsection?
Yes, yes you do.
In Placebo We Trust - Resident Obnoxious Objective Fangirl (R.O.O.F) - Your Eyes Cannot Hear
Haswell Overclocking Guide | Skylake Overclocking GuideCan my amp power my headphones?
https://linustechtips.com/topic/373948-usb-sound-card/#findComment-5058387
Yes, yes you do.
Very true, I even posted it a couple months ago :D
Edit: FOUND IT http://linustechtips.com/main/topic/263560-do-i-really-need-a-sound-card/ :D
https://linustechtips.com/topic/373948-usb-sound-card/#findComment-5058390
https://linustechtips.com/topic/373948-usb-sound-card/#findComment-5058424
