I'm playing GTA 5 on very high settings + 4X MSAA on my I7 2700K and GTX 970 and I am having a bit of an issue.
In general I can get anywhere from 40-60 FPS with GPU usage up to 95-99% but now when I load into the game my GPU usage is only 50-70% with a crappy 30 FPS which is annoying to play through.
Does anyone know what is going on? How can I get my GPU use up to 99% constantly?
Core i7 2700K Oc'ed 4.4 Ghz, EVGA GTX 970 ACX 2.0 SC'ed, 16 GB DDR3 RAM, 240 GB Intel 730 SSD and 2 TB 7200 RPM HDD, Zalman Z9 plus case with 7 blue LED fans, Windows 10 Preview
https://linustechtips.com/topic/368661-gpu-usage-issue/
I think you may be running out of GPU memory before you are hitting the limit of your GPU's core clock. I'm getting about 60-70% GPU usage with +80% GPU memory usage.
(using maxed out settings, aside from grass, shadows, no FXAA or MSAA, but DSR to 2400x1350 gives me consistent 60 FPS except in certain areas)
Aftermarket 980Ti >= Fury X >= Reference 980Ti > Fury > 980 > 390X > 390 >= 970 380X > 380 >= 960 > 950 >= 370 > 750Ti = 360
"The Orange Box" || CPU: i5 4690k || RAM: Kingston Hyper X Fury 16GB || Case: Aerocool DS200 (Orange) || Cooler: Cryorig R1 Ultimate || Storage: Kingston SSDNow V300 240GB + WD Black 1TB || PSU: Corsair RM750 || Mobo: ASUS Z97-A || GPU: EVGA GTX 970 FTW+
"Unnamed Form Factor Switch" || CPU: i7 6700K || RAM: Kingston HyperX Fury 16GB || Case: Phanteks Enthoo Evolv Mini ITX (White) || Cooler: Cryorig R1 Ultimate (Green Cover) || Storage: Samsung 850 Evo 1TB || PSU: XFX XTR 550W || Mobo: ASUS Z170I Pro Gaming || GPU: EVGA GTX 970 FTW+
https://linustechtips.com/topic/368661-gpu-usage-issue/#findComment-4991010
