Gaming Pc Build Help!
Solved by Guest,
http://pcpartpicker.com/p/37xMxr
Do you think this will run Minecraft, Battlefield 4, and CS:GO in 1080p at high fps? How much fps I will get in a low settings and a high settings?
Tell me something to change if its not right! I know that 970 sli is more better than 980's
Please Help!
Get one GTX 970, a 4690k i5, and a different power supply than the NEX. I used to have one but it was very loud. Get a SuperNova G2.
