i need help in memory please
Hello I own a Asus z97 Pro Gamer motherboard with an Intel i7 4790k
now Asus's QVL is a bit old
and does not register Corsair Dominator platinum in it
but CPU will work with 1600mhz 1.5v memory
and the z97 on this board goes up to 3200mhz (oc)
will the memory from that brand work ?
I don't really need fast memory (as it will be less stable)
so i can go with 1600mhz
so will it work ?
thanks
Yes will probably work fine.
Please not that if you buy e.g. 2400MHz ram, it's always backwards compatible with lower speeds.
If your motherboard settings / CPU settings are set for 1600MHz thats fine, it will just run at 1600MHz speeds.
Like someone said, QVL is outdated, most dimms work unless you buy a really rare brand..
Corsair is definitly a proper brand, and should work.
