OK so I did the one touch over clock and got 47 on 1 and 2 cores and 46 on 3 and 4. Minimum watts is 109.1 and the maximum VOLTS is 1.276. My Max temp was 71°C How do I save this over clock to where it updates the bios as well??
if you update the bios, can you just redo the auto overclock?
Either way, for me on the last page on advanced setting, there is an option to save the settings as a profile
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
