need cooler suggestion
Go to solution Solved by pwn_intended,
Since I do not know where you are located, I will assume USA.
There are many many options for you, but here are some that I have heard great things about:
The always trusty CM Hyper 212 EVO, its quite cheap and should be better than your stock cooler. Should easily keep it from boiling water, but it will still likely be toasty. The real upside is that it is CHEAP, and well under your budget. http://pcpartpicker.com/part/cooler-master-cpu-cooler-rr212e20pkr2
The bigger brother of the 212 is the 612 and should definitely outperform it but a few $$more. http://pcpartpicker.com/part/cooler-master-cpu-cooler-rrh6v213pkr1
There's an offering from Zalman that gets generally good reviews and is in between the 2 CM options for price, but in my opinion looks cooler, if that's your cup of tea. http://pcpartpicker.com/part/zalman-cpu-cooler-cnps9500aled
When in doubt, re-format.
https://linustechtips.com/topic/365789-need-cooler-suggestion/#findComment-4955388
