Mouse Trouble.............Please Help
Hey guys and girls I am looking for a gaming mouse for around $80 and need some suggestions . I palm/claw my mice. I was looking at the r.a.t. 5. dpi isn't a big deal since I will only be using a single 22" 1080p monitor. being able to buy from newegg would be nice..... Thanks in advanced!
https://linustechtips.com/topic/3616-mouse-troubleplease-help/
Um if you are a MMO gamer, then I would recommend the M90 because I cant find a retailer that sells the M95 which have improved buttons and dpi I think(or its not out yet since it was shown at CES). If you are an fps player, I would get a M65. They are both made by corsair.
Links:
M65: http://www.newegg.ca/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&N=-1&isNodeId=1&Description=M65&x=0&y=0
M90: http://www.newegg.ca/Product/Product.aspx?Item=N82E16826816007
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/3616-mouse-troubleplease-help/#findComment-45080
look at the roccat savu, it has an optical sensor 4000dpi and I like it a lot
(I palm it and I like to have my pinky dragging on a mouse pad)
I totally hated the rat 7 because i found it too wide
http://www.ncix.ca/products/?sku=72954&vpn=ROC-11-600&manufacture=Roccat&promoid=1360
Anything I write is just a comment, take is as such, there is no guarantees associated with anything I say.
ATX Portable rig (smaller than prodigy(LOL)) :  Nmedia 2800 | Gigabyte Z77x-ud3h  | Corsair HX1000 | Scythe Big Shuriken | i5 3570K  |  XFX R9 290 DoubleD | Corsair Vengeance 32GB
https://linustechtips.com/topic/3616-mouse-troubleplease-help/#findComment-45106
Links:
i really like the M65. i like the adjustable weights. is it better than the rat 5 though?
https://linustechtips.com/topic/3616-mouse-troubleplease-help/#findComment-46918
Links:
I think the RAT 5 is more customizable than the M65.
https://linustechtips.com/topic/3616-mouse-troubleplease-help/#findComment-46930
