Ok, so I was planning to start a music YouTube channel. But instead of posting videos showing just a picture of something... I wanted to put an audio visualizer in the video so that it could be a bit more entertaining. (I know that there might be some people who like watching visualizers, and I have nothing against that xD)
But I found out that all of these require After Effects to make... and the computer I use on a daily is just a mainstream $400 AMD laptop. Specs are as follows:
ASUS K55N-DS81 15.6"
  • AMD A8-4500M Quad-Core @ 1.9 GHz
  • Samsung 4 GB DDR3L-800 CAS 11
  • AMD Radeon HD 7640G (Integrated Graphics) 512 MB, 650 MHz Core, 800 MHz Memory
  • 1366x768 Display
  • Hitachi Travelstar 500 GB 5400 RPM 2.5"
Are these specs enough to make a 720p audio visualizer in After Effects (any version)? I'm planning to get After Effects CS3; are audio visualizers supported in this version?
CPU rendering ONLY! I don't mind playing the waiting game, and GPU rendering makes my CPU overheat and crash...
kompooterz.
https://linustechtips.com/topic/359779-a-few-after-effects-questions/
dont know about CS3 but on any new version of AE you will want to rip your hair out as every letter you type will take 10 seconds to show
