So here is how it started this time,  I was listening to music and I heard a deep kind of bump sound of sorts and suddenly the music sounded like it was coming from above me about 20° to the left. I have no idea what caused this as I had my hands off the keyboard and mouse at the time and after a several restarts and double checking of cables the problem had not been fixed
I've had some other similar problems in the past but never have found a distinctive fix for the problem, its more like hiding them under the rug.
I did some more testing in CSGO and found that the sound was unidirectional(cardioid) and I've had going bidirectional at times in ArmA 2 a while back.
The problem is that I don't know of any options really to mess around with and see if I can fix this and I don't know if its hardware or drivers or whatever.
I have tested this on two different headsets and both have the same problem.
Also in CSGO when the sound is unidirectional it has amazing directional quality, to the point that I would describe "normal" sound I was use to as unclear and muddy. Getting that working in omnidirectional would be amazing if there is something I can I to get that
I have every once in a while when my audio completely messes up, goes static and gets louder but I can still roughly tell sounds and the only fix I have found to this is to restart the computer.
Some fixes for this stuff would be a fantastic.
Info:
Win 8.1 64 bit
G1 sniper M5 motherboard
GTX 770 windforce
i7 4770k
(no audio card)
if any more information is needed just ask.
Thanks
https://linustechtips.com/topic/359728-weird-audio-problems/
