Hello everyone,
I have to switch from my cable ISP to VDSL in Germany.
Sadly I am running a coaxial cable from the cellar up to my buro on the first floor.
This is where the router sits with wireless disabled running CAT 6a to two locations in the house (bedroom/living room) where I have two Acces Points (TP-Link N750) to serve the surrounding devices (Synology, PS4, PCs, etc.) via CAT 6a and Wireless.
Now the new ISP will allow me to put the router anywhere in the house where I have a telephone jack.
There is one in the hallway (right in the middle of the house) and next to the cable input in the Cellar.
What can i do to use my CAT6a infrastructure or what would be a new solution without running new cables anywhere?
My thoughts:
1: Putting the router in the Hallway, use one of the N750 in bridge mode to grab the internet signal (easy solution).
    Question: Am i limited to the wireless bridging speed or does overall network connectivity just "skip" the bridge and the routing keep place in the "old" infrastructure? Example task: I download a file from my Synology connected to N750 (which gets the internet signal in bridge mode from the ISP router) to my computer which is        connected to N750b all via CAT6a. Does the network just use the "required" devices or is the new ISP router now somehow involved for routing slowing down the entire infrastructure? I hope this makes sense. If you tell me no, then I would be happy already. If you tell me yes it will slow down the system, then I have another question.
2. Can i Connect the Coaxial infrastructure to the new router (which only has LAN ports) somehow?
This is my first post here, thank you very much!!
https://linustechtips.com/topic/359551-wireless-home-setup/
"2. Can i Connect the Coaxial infrastructure to the new router (which only has LAN ports) somehow?" Doesn't VDSL only come from the telephone jacks not the coaxial ones?
And could power line internet help with this?
https://linustechtips.com/topic/359551-wireless-home-setup/#findComment-4876792
If there is an option to turn off NAT within your ISPs box then it should function as just a modem and it shouldn't hinder the flow of the traffic as the N750 will be doing the routing. Is the ISPs gateway connected wirelessly to your N750 or is it wired?
CPU: Core i7 4770K @ 3.5GHz Motherboard: ASUS Z87-EXPERT RAM: Corsair Vengeance 32GB (4x8GB) 1600 MHz GPU(s): EVGA GTX 980 Classified SLI Case: Coolermaster HAF X Storage: Samsung 256 GB 840 Pro, 2x2TB WD Caviar Black, 2x4TB WD Green PSU: Corsair AX860 860W Display: LG 31MU97-B 4K(4096x2160) and Dell S2716DG 27in 2K 1440p 144hz, Cooling: Noctua NH-D15 Keyboard: Corsair K70 with Cherry MX Blue switches Mouse: Razer Naga Epic Chroma and Death Adder Chroma Sound:Audioengine D1 Dac and Sennheiser HD650 Operating System: Win 10 Pro
https://linustechtips.com/topic/359551-wireless-home-setup/#findComment-4881282
