Are custom sleeved cables any good? How hard is it to make them with the Heatshrinkless style and how long do a full set take to make?
Current Rig:   CPU: AMD 1950X @4Ghz. Cooler: Enermax Liqtech TR4 360. Motherboard:Asus Zenith Extreme. RAM: 8GB Crucial DDR4 3666. GPU: Reference GTX 970  SSD: 250GB Samsung 970 EVO.  HDD: Seagate Barracuda 7200.14 2TB. Case: Phanteks Enthoo Pro. PSU: Corsair RM1000X. OS: Windows 10 Pro UEFI mode  (installed on SSD)
Peripherals:  Display: Acer XB272 1080p 240Hz G Sync Keyboard: Corsair K95 RGB Brown Mouse: Logitech G502 RGB Headhet: Roccat XTD 5.1 analogue
Daily Devices:Sony Xperia XZ1 Compact and 128GB iPad Pro
https://linustechtips.com/topic/359064-custom-sleeved-cables/
http://mainframecustom.com/ jaystwocents used them
On 11/19/2014 at 2:14 PM, Syntaxvgm said:
You would think Ubisoft would support the Bulldozer based architectures more given their digging themed names like bulldozer, Piledriver, Steamroller and Excavator.
https://linustechtips.com/topic/359064-custom-sleeved-cables/#findComment-4871223
Jays cables are made by Sanctum Sleeving, but Joe uses sleeve from MainFrameCustoms.
If you are planning on do this yourself, when you buy your supplies buy extra, and give yourself and entire weekend to do it.
Even those that have been sleeving for years can take a couple of days to do a full set, some take longer.
As you are UK based I suggest E22 (e22.biz) Their facebook is located here. They will have everything you need.
Official Profile for Addon Customs LTD and Custom Acrylics
Addon Customs -
Custom LED Lighting | Single colour and RGB available, hand sleeved | Now making Phanteks Case compatible LED KITS
Custom Acrylics - Custom computer parts | GPU backplates, Fan Grills, NZXT H440 Fascias and PSU covers | 3D printing and Laser Cutting Service available.
https://linustechtips.com/topic/359064-custom-sleeved-cables/#findComment-4872711
