Cooler Master Hyper 212+
By
Kidbest100
in Cooling
in Cooling
Solved by mgsstar,
The mounting points for LGA 1156 and LGA 1150 are the same so you can fit your LGA 1156 cooler onto a LGA 1150 socket. Used this video for installing my cpu cooler:
The mounting instructions for the Evo and Plus should be the same.
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
4
derekchan ·
Posted in New Builds and Planning8 -
1
2
6
5
7
kerriya ·
Posted in Cases and Mods13
play_circle_filled
Latest From ShortCircuit:
