I mistakenly switched modes and now I cannot switch it back. It is an AOC 2330v  has one DVI and one RGB D-SUB 15 Pin, which i assumed was VGA.   As soon as it is plugged in the screen turns on and where it should say DVI or DVI-I it says  D-SUB then promptly says no signal and turns off.  I cant switch it back without having it on and the few seconds it is on is not responding to my calm and easy pressing of the OSD button, nor to my angry rapid pressing of this one circle input.  I don't what else to do , try and find a DVi to D-SUB.. is that even a thing.  I have a Male to male D-SUB cable but nothing to plug it into.   Maybe if i cuddle with it the display will work for me...
https://linustechtips.com/topic/357526-no-signal/
Yeah i do have a DVi/VGA adapter . I think it will fit where i need it. I did attempt to hook it to an old Asus nForce motherboard but it has VGA 9 pin( male DE-9) so that was not happening, I will drag the AOC out later and give it a try.  I don't know why but i thought the adapter had Male  DE-15 Pins...
https://linustechtips.com/topic/357526-no-signal/#findComment-4855386
