My hard drive has started to work slow day by day.
I am scared that is it gonna die soon.pls tell me what the problem might be pls help me.
Thank you
Hey dev_1523,
If you give us the brand and the model of the drive, we might be able to help you. I would suggest running a diagnostic utility to check the drive's health and see what the problem might be. I would recommend using the tool provided by your manufacturer. Also check if the drive is too fragmented or full and thus performing slower.
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
https://linustechtips.com/topic/357344-hard-drive-issues/#findComment-4854429
