PLEASE HELP boot issues
Solved by gurnben,
I actually bought this very same version of windows, what u need to do is go back to the windows 8 download wizard, put in ur activation code, then it will get some things ready and download windows like u did the first time and then when given the option to load windows to this PC or create isb/DVD media choose USB/DVD or create install media. I recommend using a flash drive amd reformatting using the windows 8 wizard. U should then b able to boot! Just use the included windows 8 download/upgrade tool and choose create media!I used a program to flash the iso onto the usb and now it says "an operating system wasnt found. Try disconnecting any drives that dont contain an operating system"
PLEASE HELP
