Hello, I am doing my first watercooling build and ran into the problem where the pump is not registering rpm on my motherboard sensors. I made sure that the green wire is in the righr position and blue wire is just next to it. But motherboard bios says n/a and speedfan says 0rpm.
I can feel that thepump is working...
https://linustechtips.com/topic/35569-mcp-655-pwm-problem/
I got a new pump.
While testing I hooked it up to mobo 3 pin connector and the pump shut off. I unplugged it from the mobo and it started working.
Note - during testing mobo was turned off.
Then I plugged the whole sysem to power, but pwm was still not registering.
After this, the pump could be controlled manually through pwm cables. If I short curcuit them, the pump speeds up, if I ground the green while, pump shuts off.
So I think I killed the pwm by plugging it into a 3 port mobo connector instead of the 4 port cpu connector.
https://linustechtips.com/topic/35569-mcp-655-pwm-problem/#findComment-478085
I got a new pump.
most likely not.. the only difference in the header or pin-out is the fourth wire is
for PWM control. the 3-pin would just apply 12v to the device. now trying to voltage
control a PWM circuit can result in damages. PWM does not like voltage control.
airdeano
https://linustechtips.com/topic/35569-mcp-655-pwm-problem/#findComment-478096
a lot of reasons.. not all motherboards can support all PWM. Swiftech is getting
a lot of push back because the PWM pump is not being seen (and your PWM
pump is... Swiftech) Swiftech Troubleshooting (seems there is not support for
the PWM D5 at this time).
"All the devices connected to my PWM splitter work at 100% but I cannot vary their speed"
  1. Check that the splitter mini-4 pin PWM signal cable is correctly connected to the CPU_Fan connector of the motherboard
  2. Enable "Manual Fan Control" in the motherboard BIOS
"The device(s) connected to my PWM splitter do not work"
  1. Check that the splitter power cable is connected to the power supply
  2. Check that the non-functioning device female 4-pin connector is correctly inserted in all 4 pins of the splitter connector: in effect, it may be possible to inadvertently offset the female connector by one pin by slightly forcing its insertion, so be careful about this!
"I am getting a "CPU fan error" when I turn on the computer"
  1. Make sure that a device is connected to channel 1 of the PWM splitter. If the motherboard CPU_Fan header does not read an RPM signal, it will return such error by default.
  2. Check that the device connected to Channel 1 of the PWM splitter is correctly inserted in its connector.
  3. Check that the power cable of the PWM splitter is connected to power supply.
"I connected the PWM splitter to an auxiliary 4-pin connector that was indicated as PWM capable by my Motherboard manual, but I can't vary the speed of my devices"
  1. Other than the CPU_Fan connector which is PWM enabled by default, most of the motherboards 4-pin connectors feature two methods of speed adjustment in order to allow control of both types of fans, the 3-pins which are voltage controlled, and the 4-pins which are PWM controlled. As a result, the PWM functionality must be enabled in the BIOS before it can actually work. Please consult your motherboard manual for a "how To".
  2. Since the "CPU_Fan" motherboard connector is PWM enabled by default, we recommend that you connect the splitter to the CPU_Fan connector in order to ascertain its functionality.
"I am connecting the splitter to a PWM fan controller instead of the motherboard, and it doesn't work"
  • Not all PWM fan controllers are compatible. Please read this white paper for further explanations and a list of compatible devices.
airdeano
https://linustechtips.com/topic/35569-mcp-655-pwm-problem/#findComment-478160
I checked the manual of the mobo and it specifically talk about the 4 pin pwm connector.
From the information I gathered the 2 types of pwm are directly changing voltage and actually sending signal to the motor.
It seems that this motherboards CPU connector should be real pwm.
Am I mistaken?
Attached is the page showing the pwm connector.
post-30845-0-35268000-1374680871_thumb.j
https://linustechtips.com/topic/35569-mcp-655-pwm-problem/#findComment-502707
PWM is "Pulse width modulation". There is only one type. The other type of control is just changing the voltage. As your motherboard has a fourth pin then it can "create" a PWM signal.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/35569-mcp-655-pwm-problem/#findComment-502711
Great, so now we know that the motherboard truly supports PWM.
So why would the pump not register? This is the 2nd pump now...
I do notice I get better speed if I plug it in. If it take it out during operation, the pump slows down.
Make sure your motherboard drivers and software is up-to-date and installed. Try to use your motherboard software to control the pump. Look around your BIOS. Maybe there's a setting you have to switch on. You can also usually control fan speeds in the BIOS.
https://linustechtips.com/topic/35569-mcp-655-pwm-problem/#findComment-502834
there are two versions of that specific motherboard.
both share the same for fan control..
Is Power Fan Speed enabled? if disabled, please enable it for RPM sensing.
is CPU QFAN Control enabled? if disabled, please enable it for profile speed control.
3-84 and 3-85 of the Users' Manual.
airdeano
https://linustechtips.com/topic/35569-mcp-655-pwm-problem/#findComment-503946
