I have an inspiron 1525. Judging from pictures the hard drive tray is in the same spot: to the left of the touchpad. there are probably a couple screws on the bottom with an HDD icon next to them which will loosen the tray, from there you can just slide it out. Just make sure you don't get an SSD that is wider that the HDD already in there though.
https://linustechtips.com/topic/3551-hey-need-help/#findComment-44487
i already no were it is ant all that i was jw if a ssd would work and what one
https://linustechtips.com/topic/3551-hey-need-help/#findComment-44779
No reason it shouldn't, it uses a standard 2.5" drive. I don't beleive it uses msata however, so you'll probably need an SSD that is not msata. I'm not 100% on that so it's good to check. as, mentioned make ssure it's not wider/thicker than the current HDD in there.
https://linustechtips.com/topic/3551-hey-need-help/#findComment-45298
Quite sure you can. And if you can, I would go with a hybrid drive as well, like the seagate momentus xt. But of course, a pure SSD is nice. Lol.
Antec 1100
Asrock 970 Extreme4
955 @ 3.5Ghz
XMS3 16gb
Spahhire HD 7950
OCZ ModXStream 700W
OCZ Agility 3 120GB
https://linustechtips.com/topic/3551-hey-need-help/#findComment-45333
what would be faster a ssd or the hybrid one i have windows 8 pro i want it to boot up faster and run everthing faster
https://linustechtips.com/topic/3551-hey-need-help/#findComment-45352
ssd is faster, hybrid has more space for less
The momentus xt hybrid drive has 8 GB of an 'ssd' with either a 500GB or 750GB of your standard hdd. its like having a normal hdd with a small cache drive.
X79A GD65 (8D), 3820, 7770, 16GB (1600Mhz cas9), 850watt(ocz zx), storm trooper, h100, xonar xense, sp2500, pc350, asus PA248Q LG 22'' ips, razor black-widow ultimate 2013, 120GB intel 520 series 128GB crucial M4 2*3TB barracuda 2*1TB barracuda 2TB Hitachi
https://linustechtips.com/topic/3551-hey-need-help/#findComment-45357
Well, the SSD will always beat a hybrid or a hard drive of that matter.
Antec 1100
Asrock 970 Extreme4
955 @ 3.5Ghz
XMS3 16gb
Spahhire HD 7950
OCZ ModXStream 700W
OCZ Agility 3 120GB
https://linustechtips.com/topic/3551-hey-need-help/#findComment-45806
