I'm using wifi and the router is downstairs but my mom is hooked up via eithernet so i did speedtest on both off our computers. Would having powerline to my computer help my download speed? o: i get ~2mb/s over wifi right now
mine: http://www.speedtest.net/my-result/2834401374
hers: http://www.speedtest.net/my-result/2834397488
edit: will this one be good? http://www.newegg.com/Product/Product.aspx?Item=N82E16833156435
Case: NZXT Phantom PSU: EVGA G2 650w Motherboard: Asus Z97-Pro (Wifi-AC) CPU: 4690K @4.2ghz/1.2V Cooler: Noctua NH-D15 Ram: Kingston HyperX FURY 16GB 1866mhz GPU: Gigabyte G1 GTX970 Storage: (2x) WD Caviar Blue 1TB, Crucial MX100 256GB SSD, Samsung 840 SSD Wifi: TP Link WDN4800
Donkeys are love, Donkeys are life.                    "No answer means no problem!" - Luke 2015
https://linustechtips.com/topic/35503-will-powerline-help-me/
well you get 12mBs and she gets 30mBs.
powerline would help but the effiency of it varies depending on how old your house is.
i can get 400 mbs comp to comp using mine so powerline is definately better than wifi but isn t as good as cat5
Anything I write is just a comment, take is as such, there is no guarantees associated with anything I say.
ATX Portable rig (smaller than prodigy(LOL)) :  Nmedia 2800 | Gigabyte Z77x-ud3h  | Corsair HX1000 | Scythe Big Shuriken | i5 3570K  |  XFX R9 290 DoubleD | Corsair Vengeance 32GB
https://linustechtips.com/topic/35503-will-powerline-help-me/#findComment-454797
double post
https://linustechtips.com/topic/35503-will-powerline-help-me/#findComment-454801
Yes powerline is WAY better than Wireless 802.11n however with the emergence of 802.11ac that delivers Gigabit speeds through wireless that would be the way to go.
By the way to go i mean 802.11ac is the best fastest wireless choice right now unless you get CAT6
Edited by AMD Lover
Work Desktop | CPU: Intel Core i7 4770k | GPU: Quadro K1200 | Motherboard: EVGA Z97 Classified | RAM: Corsair Dominator Platinum 32GB (4x8GB) DDR3-2133Mhz | PSU: Seasonic 750W SS-750KM3 80 PLUS Gold | STORAGE: WD 1TB Se Enterprise Grade Drive & Corsair Neutron NX500 400GB NVMe PCIe  | COOLER: Enermax Liqtech 240 -  5x Noctua NF-F12 iPPC 2000 PWM | CASE: Corsair 600C | OS: Windows 10 Pro | Peripherals: Logitech MX Master 2S -- Logitech K840 -- INTEL X520 10Gb NIC -- 3x Acer H236HL -- Build Log |
Work Server | CPU: Intel Xeon E5-2650 v3 | Model: Cisco UCS C220 M4 (SFF) | RAM: 64GB (4x16GB) Cisco (Samsung) DDR4 2133Mhz | STORAGE: 4x Cisco (Seagate) 900GB 10K 2.5" (RAID 10) - 2x 32GB Cisco FlexFlash Boot Drive (RAID 1) | OS: vSphere 6.7 Enterprise Plus U3 |
Laptop | CPU: Intel Core i7 6700HQ | GPU: Nvidia GTX 960M 2GB GDDR5 | RAM: 32GB (2 x 16GB) DDR4-2400Mhz | STORAGE: 512GB Hynix NVMe | OS: Windows 10 Pro |
Gaming Desktop | CPU: Intel Core i7 9700K | GPU: Gigabyte RTX 2080 WINDFORCE 8G  | Motherboard: ASRock Z390 PHANTOM GAMING-ITX | RAM: Ballistix Elite 32GB Kit (16GB x 2) DDR4-3000 | PSU: Silverstone SX700-LPT 700w 80 PLUS Platinum | STORAGE: 2x Samsung 970 PRO 1TB NVMe | COOLER: Noctua NH-L12 | CASE: Louqe Ghost S1 | OS: Windows 10 Pro | Build Log in Progress |
Home Server | CPU: Intel Xeon E5-2690 (Sandy Bridge) | GPU: Quadro P2000 | Motherboard: SUPERMICRO X9SRL-F  | RAM: 64GB (8x8GB) Micron VLP DDR3-1600 ECC | PSU: SUPERMICRO 665W 80 PLUS Bronze | STORAGE: 2x Samsung 860 EVO 500GB (RAID 1) - 4x WD 8TB Ultrastar (RAID 10) - Intel SSD D3-S4510 Series 240GB (BOOT)  | COOLER: Noctua NH-U12DXi4 with 2x Noctua NF-F12 iPPC 3000 PWM | CASE: SUPERMICRO CSE-842TQ-665B 4U | OS: vSphere 6.7 Enterprise Plus U3 | Build Log in Progress |
| Pixel 4XL 128GB - Clearly White - Unlocked - Carrier: Visible |
| F@H STATS |
https://linustechtips.com/topic/35503-will-powerline-help-me/#findComment-455086
Powerline WILL be more stable than WiFi for 99% of the cases. But as stated above, it also depends on the quality of your electrical installation and if you have 380V on the same electrical panel. Make sure you get high speed powerline devices, not those old 80Mbit/s ones.
https://linustechtips.com/topic/35503-will-powerline-help-me/#findComment-455747
wifi ac has trouble doing faster than 500mbps with any kind of interference (5ghz and all) and it cost 200$ for a router plus 100$ for an adapter.
it isn t worth it for op where 2.4ghz doesn t have enough power to reach his pc
https://linustechtips.com/topic/35503-will-powerline-help-me/#findComment-456395
well we added onto our house a few years back and the router is in the newer part of the house so has newer electrical but my room is in the older part so the powerline will go from newer to older electrical, and the house was built some 200 years ago >_<
https://linustechtips.com/topic/35503-will-powerline-help-me/#findComment-456868
Just make sure both rooms are on the same electrical panel and you should be fine. Give it a try first if you have a friend with 2 powerline adapters, just in case.
https://linustechtips.com/topic/35503-will-powerline-help-me/#findComment-457305
I have heard that powerline does cause an increase in ping (latency)
It may in certain cases, but you usually end up with consistent ping, which is good. The problem with sharing a medium between networking and electricity is that you can get interferences from electrical devices in rare cases.
https://linustechtips.com/topic/35503-will-powerline-help-me/#findComment-457437
