Crash (x-post from r/pcmasterrace)
Solved by Jade,
Sorry. Can I fix it?
Don't worry about it. I just get irritated by small things. But @ stock speeds: Some applications can cause the program to crash due to bad drivers or handling display badly. For example, under more than acceptable temps (40c), my PC is regularly crashed by the game "Damned" because it handles display poorly. You could try to update your drivers to fix it, or switch to some "known-good" older ones.
