I'm lazy and don't want to sleeve cables myself. Could anyone link me to some pre-sleeved cables?
Edit: I have a SeaSonic 850w power supply and want replacement cables that have nice red sleeving.
System Specs - CPU: i7 4770K - RAM: 8GB(2x4GB) Vengeance Pro - Motherboard: Maximus VI Gene - Case: Modded PowerMac G5 - CPU Cooler: H100i - PSU: AX860i - SSD: Samsung 840 Series 120GB and Kingston V300 120GB - HDD: Seagate Barracuda 1TB - Graphics Card: 2x GTX 780 - Case Fans: SP120s and Spectre 140s - Headphones: HD700, Alpha Dog, SE215
Sony A7R w/ Zeiss 55mm F1.8
https://linustechtips.com/topic/35311-pre-sleeved-cables/
Im thinking of getting some Bitfenix extensions to make the whole build look nicer Amazon would be the best place to look for them
 Asus M5A99X Evo  - AMD FX-8350 - 16GB Corsair Vengeance 1866Mhz - Corsair 120mm Quiet Edition Fans BenQ XL2411Z- EVGA GTX 980 Superclocked Fractal Design Define R4 - Corsair H100i - 2 TB 7200rpm HDD - Samsung 840 Evo 120GB - Corsair RM750w PSU - Logitech G502 Proteus Core - Corsair K70 RGB MX Red - Audio Technica M50x + Modmic 4.0 - LG 23EA63V x2
Spinthat Spinthat Spinthat Spinthat
https://linustechtips.com/topic/35311-pre-sleeved-cables/#findComment-452506
I use the bitfenix extensions they are really nice and i would recommend them.
My Build  CPU: AMD Phenom II X4 955@4.1@Ghz Mobo: Asus M5A99x Evo R2.0 GPU: Asus 7870T @1.25GHz Core 5.5GHz Mem Ram: Kingston HyperX@ 1600 9-9-9-24 CPU Cooler: H80 Push/Pull Noctua NF-P12  SSD: Samsung 128GB 840 PRO HDD: Mix of drives which add up to 5.6TB SoundCard: Asus xonar DGX PSU: Corsair HX650 + alchemy cables Case: R3 with the rest of the fans being fractel fans.
Im A Snake.....
https://linustechtips.com/topic/35311-pre-sleeved-cables/#findComment-452518
Without knowing the PSU brand, we can't recommend what cables to get because companies have different connectors for the PSU. I know Corsair has their own sleeved cables that they sell for their modular PSU's but they are ludicrously expensive.
Bitfenix extensions are pretty nice and, in relative terms, cheaper compared to the pre-sleeved replacement cables.
| Corsair Carbide Series 350D |Corsair H100i | Intel i7 5820k @ 4.5GHz, 1.175v | EVGA x99 Micro 2 | G.Skill Trident Z 32gb, 3200MHz
| Gigabyte G1 Gaming 980Ti @1506MHz | EVGA P2 850 Watt | 2x Samsung 850 Evo 500gb | Western Digital Red Pro 6TB |
https://linustechtips.com/topic/35311-pre-sleeved-cables/#findComment-452558
