Help with skyrim textures
Go to solution Solved by Wadu436,
Could be, especially if that mod specifically addresses those animals.
But unless someone has experience with your exact same problem, with the exact same setup there is really no way to know - other than unistalling the mod and seeing of the problem corrects...
Modding involves so many different permutations it often comes to down to trial and error troubleshooting.
Found the culprit, it was a mod called Skyrim Immersive Creatures
I get these purple-ish trees and flora:
http://steamcommunity.com/sharedfiles/filedetails/?id=430090032
http://steamcommunity.com/sharedfiles/filedetails/?id=430090148
My PC:
i5 4430 3.0Ghz
GTX760 2Gb Asus DC2 OC edition
8Gb 1333mhz DDR3 RAM
my modlist:
http://www.modwat.ch/Wadu436#/plugins
EDIT:
Steam apparently doesn't work so ill reupload the pictures
post-121623-0-06976000-1429716062_thumb.
post-121623-0-68503500-1429716063_thumb.
post-121623-0-03719400-1429716065_thumb.
post-121623-0-38996500-1429716066_thumb.
https://linustechtips.com/topic/353035-help-with-skyrim-textures/
Try redownloading your texture packs, the download may have been corrupted
Intel i7 6700k @ 4.8ghz, NZXT Kraken X61, ASUS Z170 Maximus VIII Hero, (2x8GB) Kingston DDR4 2400, 2x Sapphire Nitro Fury OC+, Thermaltake 1050W
All in a Semi Truck!:
http://linustechtips.com/main/topic/519811-semi-truck-gaming-pc/#entry6905347
Purple objects tend to indicate that you are running out of VRAM memory - the program cannot find the proper textures.  Try turning down your graphics settings, or using less detailed versions of any graphics mods.
I was able to fix it by enabling my optimized textures from my previous mod setup (I'm using MO), but now there is a problem that some animals (deer, mudcrab, some wolves) dont have a textures. I think its maybe a problem with the mod called Animallica?
