heat dissipation
Solved by ADZ_123_!"£,
does liquid cooling rads have less heat? how big is the heat difference when using air cool.
Both dissipate the same amount of heat into your room if you had 2 cpus both creating the same heat then they would both emit the same amount of heat it's just that under water you can generally get a higher clock so the cpu gets hotter and more heat is put in your room.
VirusDumb ·
Posted in Programming0 -
Jayraj ·
Posted in Power Supplies0 -
Airmack ·
Posted in Graphics Cards0 -
Kyle89 ·
Posted in Troubleshooting2 -
7
5
ken43 ·
Posted in Troubleshooting5 -
8
thedood2k ·
Posted in Power Supplies3
play_circle_filled
Latest From Linus Tech Tips:
play_circle_filled
Latest From ShortCircuit:
