I have a problem with a 40 inch Samsung LCD TV.
It turns on, I get sound, but no color, it is emiting light, just all black.
I can see the backlight or whatever turn on but there is no color the the picture, tried all different inputs, HDMI, VGI Composite. All the same sound, and light, but no color.
https://linustechtips.com/topic/35177-lcd-tv-color-problem/
Have you tried connecting it to a different device i.e. another computer, cable box?
Try this:
Go into the "service menu" using the remote and look for the "DDR" option and change it to "Samsung"
To find out how to get into the service menu go here: http://factory-reset.com/wiki/Samsung_Service_Menu and find what button combo you need to do for your tv (the service menu is NOT the normal menu).
If that doesn't work then it will probably need to be RMA'd
| Currently no gaming rig | Dell XPS 13 (9343) |
| Samsung Galaxy Note5 | Gear VR | Nvidia Shield Tab | Xbox One |
https://linustechtips.com/topic/35177-lcd-tv-color-problem/#findComment-450732
Oh damn, ok well only other thing is to try a differnt power outlet otherwise it's an RMA unless anyone else has any suggestions. :(
https://linustechtips.com/topic/35177-lcd-tv-color-problem/#findComment-450871
Problem is it just ran out of warranty.
That is the beauty of a warranty period manufactures know how long their products last before they will fail.
Super OP AF Killer Retro Emulation PC 360 No Scope 420 Blaze It (Sorry I Couldn't Help It) Seriously Though This PC Is Overkill And Before You Ask It Does Play Crysis 1024x768 60 FPS
Intel Core Duo 2 Quad Q9550 @ 2.83GHz // ASUS P5N-D // Zalman CNPS9500A Air Cooler // 4GB G.Skill @ 400MHz 5 5 5 31 23 // 2 Way SLI GeForce 9800 GTX+ // 32" SONY WEGA CRT TV 480i // Corsair TX750 // Seagate 3TB // Win XP 32Bit // Sony DVD RW // ANTEC Full Tower // Steel Series H Wireless // Logitech K520 Wireless Keyboard // Logitech M510 Wireless Mouse // Logitech G27 Racing Wheel // Thrustmaster T-Flight HOTAS // HORI Fight Stick Mini // 8Bitdo NES30 Pro / FC30 Pro / SNES30 / SFC30 Bluetooth Controllers
Future Upgrades The New 8Bitdo Wireless SNES Controller With Analog Sticks / 8Bitdo Bluetooth Arcade Fight Stick / Proper HD I Know This Machine Does Not Support 3 TB / Icy Dock 5.25 4 Bay HD Hot Swap Bay For More Seamless Multi Booting Want To Run At Least Win 95, Win XP, Win 7
i7 3770k @ 4.5Ghz // ASUS Maximus V Formula // CM Hyper 212 EVO // 16GB G.Skill Sniper @ 2133MHz 9 11 10 28 // Crossfire Sapphire 7970 // 42" 4K 60Hz FreeSync WasabiMango IPS // Corsair AX860 // Samsung 1TB 840EVO // Seagate 3TB // Seagate Barracuda 160GB sata II // OCZ Vertex 3 90GB sata III // Win 10 64Bit // ASUS DVD RW // 2 Corsair AF 120 // 2 Corsair SP 120 // 2 xigmatek 120 // Corsair 760t white flavor // NZXT HUE+ RGB Controller // Sennheiser G4me Zero // Steel Series H // Corsair M95 // Corsair K95 // 3 Xbox 360 Controllers // Dolphin Bar // Wii U Mote // Leap Motion Plus // Logitech G27 Racing Wheel // Thrustmaster T-Flight HOTAS // HORI Fight Stick Mini // 8Bitdo NES30 Pro / FC30 Pro / SNES30 / SFC30 Bluetooth Controllers
Future Upgrades 1080Ti or Vega RX64 http://linustechtips.com/main/topic/16900-nothing-special/
https://linustechtips.com/topic/35177-lcd-tv-color-problem/#findComment-453600
Thats just samsung quality also, and the reason i don't buy their screens anymore.
Probably a cap died if this the case might be easy and cheap fix.
How would I check for that, and sounds like I would need a soldering iron, which I don't have.
https://linustechtips.com/topic/35177-lcd-tv-color-problem/#findComment-455023
You could investigate on your own, then if indeed the case you should see some bad caps then just send it to a repair center.
Or you could buy new tv tough i would avoid anything from samsung this time.
Well I didn't buy the first one, and I was only looking to fix this one so I could have one in my room, but not worth all that hassle.
https://linustechtips.com/topic/35177-lcd-tv-color-problem/#findComment-456555
