Totally overkill case and CPU cooler, but it's all in the name of silence!
CPU Cooler: Cooler Master Nepton 240M 76.0 CFM Liquid CPU Cooler  ($108.99 @ SuperBiiz)
Motherboard: MSI H81M-E34 Micro ATX LGA1150 Motherboard  ($49.99 @ SuperBiiz)
Storage: PNY CS1111 120GB 2.5" Solid State Drive  ($49.99 @ Micro Center)
Video Card: EVGA GeForce GTX 970 4GB SSC ACX 2.0 Video Card  ($315.04 @ Amazon)
Total: $988.94
Generated by PCPartPicker 2015-04-20 11:35 EDT-0400
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/351734-1000-best-pc-build/#findComment-4782213
It's 11 over budget, but you get a beast processor, silent cooling, and a silent case.  This would be an awesome build.
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($326.99 @ SuperBiiz)
CPU Cooler: Noctua NH-D9L 46.4 CFM CPU Cooler  ($49.97 @ NCIX US)
Motherboard: ASRock Z97 PRO3 ATX LGA1150 Motherboard  ($88.98 @ OutletPC)
Memory: A-Data XPG V2 8GB (2 x 4GB) DDR3-1866 Memory  ($51.99 @ Newegg)
Video Card: Asus GeForce GTX 970 4GB STRIX Video Card  ($323.99 @ SuperBiiz)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($39.99 @ NCIX US)
Total: $1011.20
Generated by PCPartPicker 2015-04-20 11:47 EDT-0400
Case: HAF XBCPU: 4690kCPU Cooler: NH D15Motherboard: Gigabyte Gaming 7 | RAM: Hyper X FuryVideo Card: G1 Gaming 970SSD: 850 EVO |  PSU: Supernova 550 G2 |
https://linustechtips.com/topic/351734-1000-best-pc-build/#findComment-4782281
Total: $1011.20
.... except for the lack of the OS and the SSD.
https://linustechtips.com/topic/351734-1000-best-pc-build/#findComment-4782352
OP didn't ask for an OS, and you didn't put one in your build either.  SSD is a nice feature to have, but certainly not at all necessary.
https://linustechtips.com/topic/351734-1000-best-pc-build/#findComment-4782406
Oh, so he should use Linux for gaming?
Also, please look carefully at my build.
Total: $988.94
https://linustechtips.com/topic/351734-1000-best-pc-build/#findComment-4782657
Reading comprehension... sigh.
You didn't include an OS in your build either.  Usually it would be asked for in the original post if it's needed as part of the budget.  Since he did not ask for one, neither you nor I included one.  Does that make sense?
https://linustechtips.com/topic/351734-1000-best-pc-build/#findComment-4782806
Oh... I suck. So much. I was pretty sure I didn't do that mistake.....
https://linustechtips.com/topic/351734-1000-best-pc-build/#findComment-4782836
