Pump replacement help.
Go to solution Solved by Necrodead,
Tiny Tom said in his video that its 'technically' a laing DDC, but Swiftech responded saying that its a swiftech made pump and not 'technically a DDC' so I'm assuming the 2 are identical in specs but different manufaturer.
So I recently bought a 2nd hand swiftech H220 AIO off ebay that i wanted for a tiny steam pc build. But when it arrived the pump stunk of electrical smoke and wasn't working. Ebay at it's finest again. Lucky I didn't pay too much for it.
I need someone who might know or have some good technical knowledge to see if this Alphacool Laing DCC310 pump looks to be a good replacement.
The measurements of both the swiftech pump and the Alphacool one match. And from just eye-balling it, the pump blades look to function in the same way.
https://linustechtips.com/topic/350489-pump-replacement-help/
Well it's not ebays fault that it came broken. Honestly I think your best bet is to contact the seller and let them know it's not working and get your money back, and get a different one off of a trusted dealer.
CPU: Ryzen 5 5600 Motherboard: MSI B550 Tomahawk RAM: 32Gb DDR4  GPU(s): MSI 6800-XT Case: NZXT H440 Storage: 4x 250gb SSD + 2TB HDD PSU: Corsair RM850x with CableMod Displays: 1 x Asus ROG Swift And 3 x 24" 1080p Cooling: H100i Keyboard: Corsair K70 RGB Mouse: Corsair M65 RGB Sound: AKG 553 Operating System: Windows 10
Current PC:
http://i.imgur.com/ubYSO3f.jpg          http://i.imgur.com/xhpDcqd.jpg
https://linustechtips.com/topic/350489-pump-replacement-help/#findComment-4767457
https://linustechtips.com/topic/350489-pump-replacement-help/#findComment-4767536
