Is it normal for me to get 20 - 45 FPS in ARMA 3 with my current build? I play @1080p Ultra. I tried disabling all AAs and setting Shadows to low with no improvements at all. Is there something wrong with my computer or is this normal?
System:
Intel Core i5 4690k @ 3.5Ghz, MSI z97 PC Mate, Gigabyte GTX 970 G1 gaming, 4x2 Kingston HyperX blu 1600Mhz, 1 Tb Seagate Barracuda 7200rpm, Corsair CX600M PSU, Corsair AF120 Performance edition 3x, Xigmatek Stock fans 3x, Xigmatek Mach PC Case, Asus VX239H 1080p IPS LED 23".
https://linustechtips.com/topic/349553-arma-3-low-fps/
Welcome to the Arma engine. That is a bit low but it is a notoriously horribly optimized engine. I would update drivers (clean reinstall if they are up to date). Try tinkering with the various render distances too that has a huge effect on performance.
"If you do not take your failures seriously you will continue to fail"
https://linustechtips.com/topic/349553-arma-3-low-fps/#findComment-4756247
I actually tried setting field of view to "0", and nothing changed, is that what you mean?
System:
https://linustechtips.com/topic/349553-arma-3-low-fps/#findComment-4756266
No render distance. Its been a long time since I've played Arma but there should be sliders for "draw distance" then something like "detail draw distance" and a few sliders like that. If you play around with those you might get better fps. I used to be able to get a max of 60-70 (with the lowered draw distance) in forested areas but it would drop back down really low during combat or in cities. I have a 660ti also.
https://linustechtips.com/topic/349553-arma-3-low-fps/#findComment-4758590
OC your i5 to 4ghz it should give you a nice fps boost
        Sample Text ( ͡° ͜ʖ ͡°)
https://linustechtips.com/topic/349553-arma-3-low-fps/#findComment-4759637
