I will probably overclock the GPU to 1.35GHz, and the CPU to about 4.2GHz or so. I will be playing mostly TF2, Battlefeild Hardline, Cities Skyline, and maybe some Warface.
My budget is about $900 but i have some wiggle room if you can prove its worth it. Im also using a laptop to record my gameplay from a Elgato GCHD to a OBS. I have a 5TB external hard drive so storage is not a problem.
98158fc3728d448b22cfdd6d49ab75ef.med.160dbe16fe40d2d607553ca575c143e9094.med.160
EVGA GTX 970 - i5 4460 - Enthoo Pro M
https://linustechtips.com/topic/348991-my-first-pc-build/
Looks awesome man you have great cpu for gaming awesome board and everything my one recommendation would be to tell You to color coordinate and only expect to play at 1080p
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
https://linustechtips.com/topic/348991-my-first-pc-build/#findComment-4749426
Looks amazing. You're going to have so much fun with that build, it's a great build. Have fun building it too! Best of luck! Hopefully it doesn't take 2 weeks like mine did because I am dumb and was re-using dell parts which I now know are custom.... That PSU gives you room to upgrade to SLI if you want (Which I would recommend) I would aos recommend getting an SSD, even if it's just for booting, they are amazing, I have 4... I went a LITTLE overboard with them...
CPU: Ryzen 5 5600 Motherboard: MSI B550 Tomahawk RAM: 32Gb DDR4  GPU(s): MSI 6800-XT Case: NZXT H440 Storage: 4x 250gb SSD + 2TB HDD PSU: Corsair RM850x with CableMod Displays: 1 x Asus ROG Swift And 3 x 24" 1080p Cooling: H100i Keyboard: Corsair K70 RGB Mouse: Corsair M65 RGB Sound: AKG 553 Operating System: Windows 10
Current PC:
http://i.imgur.com/ubYSO3f.jpg          http://i.imgur.com/xhpDcqd.jpg
https://linustechtips.com/topic/348991-my-first-pc-build/#findComment-4749468
like your 5.1GHz overclock, it doesn't exist.
you sir, have no idea what your talking about
But i see you point my Profile and signature are wrong I actually have a 9370 @ 5.1 GHZ. Ive been to lazy to change it because 9370 is literally the same thing as 9590 just clocked slower
touche'
Current: R2600X@4.0GHz\\ Corsair Air 280x \\ RTX 2070 \\ 16GB DDR3 2666 \\ 1KW EVGA Supernova\\ Asus B450 TUF
Old Systems: A6 5200 APU -- A10 7800K + HD6670 -- FX 9370 + 2X R9 290 -- G3258 + R9 280 -- 4690K + RX480
https://linustechtips.com/topic/348991-my-first-pc-build/#findComment-4749617
How about this?
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor ($173.95 @ SuperBiiz)
Motherboard: MSI B85M-G43 Micro ATX LGA1150 Motherboard ($69.95 @ OutletPC)
Memory: G.Skill Ripjaws X Series 8GB (1 x 8GB) DDR3-1600 Memory ($49.99 @ Newegg)
Storage: Hitachi Ultrastar 1TB 3.5" 7200RPM Internal Hard Drive ($42.00 @ Amazon)
Video Card: Sapphire Radeon R9 290 4GB Tri-X OC Video Card (2-Way CrossFire) ($259.99 @ Newegg)
Case: Fractal Design Core 1100 MicroATX Mini Tower Case ($24.99 @ NCIX US)
Power Supply: EVGA SuperNOVA NEX 750W 80+ Bronze Certified Semi-Modular ATX Power Supply ($73.99 @ SuperBiiz)
Total: $954.85
Generated by PCPartPicker 2015-04-16 08:08 EDT-0400
290s will beat the 970
https://linustechtips.com/topic/348991-my-first-pc-build/#findComment-4751525
You spec'd a $900 PC and couldn't get SLI capabilities? For shame.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($199.99 @ Micro Center)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  ($110.98 @ Newegg)
Video Card: Asus GeForce GTX 970 4GB STRIX Video Card  ($323.99 @ SuperBiiz)
Total: $919.77
Generated by PCPartPicker 2015-04-16 08:26 EDT-0400
This is $5 more. The case is nicer. GPU is cheaper, comes with a deal for money off and a free game to boot. RAM is cheaper and slightly lower CAS. Mobo now has SLI capabilities. A nice improvement for $5. Also if you don't like the colour of the case, there's a Black one and an Orange one to choose from.
https://linustechtips.com/topic/348991-my-first-pc-build/#findComment-4751620
Total: $919.77
i really like the mobo you chose. i think im gonna keep the 200R though :P i really like the minimalist design and its just so easy to build in.
https://linustechtips.com/topic/348991-my-first-pc-build/#findComment-4754793
Look at internal pics of the 230T, it's basically the same as the 200r, but it looks nicer. It's been changed slightly to allow for longer secondary graphics cards. Certainly worth considering.
https://linustechtips.com/topic/348991-my-first-pc-build/#findComment-4755419
https://linustechtips.com/topic/348991-my-first-pc-build/#findComment-4755528
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($226.99 @ SuperBiiz)
CPU Cooler: Noctua NH-D14 65.0 CFM CPU Cooler  ($69.89 @ OutletPC)
Motherboard: Gigabyte GA-Z97X-UD3H ATX LGA1150 Motherboard  ($109.99 @ Micro Center)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply  ($26.99 @ Newegg)
Total: $943.43
Generated by PCPartPicker 2015-04-16 19:29 EDT-0400
This is far better. Better motherboard, far better case for almost the same price. The NEX unit PSU's get pretty loud under load so I wouldn't recommend them at all. Quite a bit of a better CPU cooler, though the 212 EVO may be fine for minor overclocks. The ACX 2.0 coolers have horrible coil whine, or so I've heard. Changed the motherboard with a more trusty motherboard, things like that, etc. I should say. Also changed the drive to a better drive. Seagate have more failure rates.
PC and Peripherals:
Intel Core i3 4150 @3.5GHz - ASRock H97M Anniversary - Kingston Fury HyperX Black 8GB DDR3 @1866MHz - Gigabyte GeForce GTX 960 G1 Gaming 2GB GDDR5 - EVGA 500W 80+ Certified - WD Caviar Blue 1TB - WD Caviar Blue 160GB - Lian Li PC-50 - Linux Ubuntu 14.04.3 LTS - Acer P221w 21.5" 1680x1050 60Hz - Kingston Fury HyperX Clouds - Razer Deathadder 3.5G - CM Storm Quickfire Rapid w/ Cherry MX Blues
https://linustechtips.com/topic/348991-my-first-pc-build/#findComment-4755811
