HELLO BROS!
I have a Casecom Buster VS-93 case, which is more of a 'budget' choice.
It has 4 fan mounts. 1 80mm on the back - 1 120mm on the front and 2 120mm on the side.
Can you guys tell me how should I set up the fans, the way that my case doesn't get hot (negative air)..
Please tell me the exact configuration of how I should mount the fans on intake or outtake.
THANKS!
https://linustechtips.com/topic/347128-need-help-with-fan-setup/
Front and side intake, and if you d o find a reasonable 80mm fan, have it as exhaust. Otherwise, leave the rear empty.
Project Depravity: £850 / ????? (03/12/2015) Case: Phanteks Enthoo Primo SE Red Keyboard: Corsair K95 RGB MX Red Monitors: 3* Asus PG279Q Stand: Ergotech Triple Desk Stand Webcam: Logitch C920
RIP in kill: CPU: Single core Celeron M @1.73GHz RAM: 1GB (512MB x2) DDR2 SO-DIMM Motherboard: Asus MOCA-AR HDD: 160GB SATA2 5400rpm
Current System: CPU: Intel i5-4690K Cooler: Cooler Master Hyper 212 EVO Motherboard: MSI Z97 Gaming 5 RAM: Kingston HyperX Fury 8GB 1866MHz GPU: Gigabyte Windforce 960 4GB SSD: Sandisk Ultra Plus 128GB HDD: WD Caviar Blue 1TB PSU: Corsair CX500M Case: Corsair 200R Windowed MonitorLG 22MP55HQ 22" IPS + HP w19 MouseRoccat Savu Keyboard: Corsair Raptor K30 Mouse Pad: Perixx DX-1000XXL Headset: Kingston HyperX Cloud OS: Windows 10 Pro 64-bit
https://linustechtips.com/topic/347128-need-help-with-fan-setup/#findComment-4725654
Do you have an open air cooler on your video card or blower design cooler?
I have R9 290 Windforce 3X.
Did that, All three intake and the back as an exhaust, it was creating negative air pressure inside the case.
Right now I have Front and 1 fan of side as intake, and others exhaust. Note that my CPU cooler is also shaped like Intel Stock cooler, it has fan on top. :)
https://linustechtips.com/topic/347128-need-help-with-fan-setup/#findComment-4725700
What kind of black magic is this? Are you sure you're getting negative pressure?
https://linustechtips.com/topic/347128-need-help-with-fan-setup/#findComment-4725749
Yep. It was getting pretty hot.
You see, on the left side panel, I have two 120mm fans. The above one blows onto CPU and the lower one blows on to GPU.
So, If I get too much intake, my case gets hot, I think the cold air from outside gets hot when it goes inside the case.. :{
Any other ideas? :{
https://linustechtips.com/topic/347128-need-help-with-fan-setup/#findComment-4725832
