HTPC CPU cooler?
I built a HTPC this week for my living room and so far its going well. However I'm using the stock intel CPU cooler and damn that thing makes some noise! I'm using a Silverstone ML04 with a 20 anniversary Pentium 1150. What low profile and quiet cooler can you recommend for up to £30ish?
https://linustechtips.com/topic/345791-htpc-cpu-cooler/
Big shuiriken b2 :)
https://linustechtips.com/topic/345791-htpc-cpu-cooler/#findComment-4709307
This one seems pretty decent for the prize:
http://www.newegg.com/Product/Product.aspx?Item=9SIA4S82KJ1273
If you prefer a 120mm fan i would go with this:
http://www.newegg.com/Product/Product.aspx?Item=9SIA59T1RU0194
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
    Asus MAXIMUS Formula VI
  • RAM
    Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz
  • GPU
    MSI GTX 1070 Gaming X
  • Case
    Cooler Master Cosmos SE
  • Storage
    Samsung 840 EVO 500GB+WD Green 3TB
  • PSU
    EVGA SuperNOVA 850G2 80PLUS Gold Certified
  • Display(s)
    ASUS PB277Q 27" WQHD 2560x1440 75Hz 1ms
  • Cooling
    Corsair H105 with AP121s and Phanteks fans
  • Keyboard
    Logitech G610 Orion
  • Mouse
    E-3lue E-Blue Mazer II 2500 DPI Blue LED 2.4GHz Wireless Optical Gaming Mouse
  • Sound
    Audio-Technica ATH-M20x
  • Operating System
    Windows 10
https://linustechtips.com/topic/345791-htpc-cpu-cooler/#findComment-4711628
