I recently upgraded to Shaw 50 internet and am having problems with range, I have two routers but only one modem, and was wondering if I should put a wifi extender (what is the best) on the modem or if I should hook up a second modem closer to where I am currently working. If I hook up a second modem I will add a third as well.
Asus Sabertooth Z77, Intel 3770K 4.6GHz @ 1.33V, EVGA GTX670, Corsair Vengeance 16GB RAM, and Corsair 800D
https://linustechtips.com/topic/3453-home-wifi-problems/
Its always best if could run a wire to where you need a connection. From what I understand you have a router/modem in one and a separate router somewhere else ?
If you aren't afraid to get your hands dirty, you could install dd-wrt on a spare router and turn that into a wi-fi extender (its a bit ghetto, but it works). And correct me if i'm wrong I don't think you can run 2 modems on one connection.
Something wrong with your connection ?
Run the damn cable :)
https://linustechtips.com/topic/3453-home-wifi-problems/#findComment-43438
depends on where you live. I have seen places use inner pair and outer pair for 2 separate connections. but generally speaking you are correct.
One Steam to rule them all, One Sale to find them, One Sale to bring them all and with their wallets, bind them! - r/pcmasterrace 17/01/2014
  • CPU: Intel Core i7 6700k
  • CPU Cooler: CM Hyper 212+
  • RAM: 16GB Kingston HyperX Fury 2400Mhz (2x8GB)
  • GPU: Gigabyte G1 R9 390
  • Mobo: Asus Z170-AR
  • PSU: Antec High Current Gamer 900W
  • Storage: 240GB intel 520 SSD (OS), Sandisk 128GB SSD(Other OS) 2x 2TB Seagate Barracuda
  • Case: Fractal Design R4
https://linustechtips.com/topic/3453-home-wifi-problems/#findComment-43968
