Building first pc
Go to solution Solved by Fatelinha,
Hi fellow mate :D
1st you should tell us if you need any monitors or peripherals.
2nd I made this build, see if it suits you.
PCPartPicker part list: http://pcpartpicker.com/p/ZbtPNG
Price breakdown by merchant: http://pcpartpicker.com/p/ZbtPNG/by_merchant/
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($324.99 @ SuperBiiz)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  ($97.98 @ OutletPC)
Motherboard: MSI Z97-GAMING 7 ATX LGA1150 Motherboard  ($169.98 @ SuperBiiz)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory  ($64.99 @ Amazon)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($106.52 @ Amazon)
Video Card: Asus GeForce GTX 980 4GB STRIX Video Card  ($549.99 @ SuperBiiz)
Case: NZXT H440 (White/Black) ATX Mid Tower Case  ($99.99 @ Newegg)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply  ($69.99 @ SuperBiiz)
Total: $1484.43
Generated by PCPartPicker 2015-04-07 13:38 EDT-0400
If you are in need of OS you can get it from G2A that is cheaper.
Good luck with your building :D
Hey guys
I'm looking to build a pc for between £1000 and £1100 I would prefer a white and black colour scheme. I would prefer it to have an i7 and a Gtx 980 as I like to render bits and pieces occasionally and do art as well as Gaming . I have a 1tb hard drive already which I was going to recycle for storage and os
Any thoughts or suggestions?
https://linustechtips.com/topic/343345-building-first-pc/
Hi fellow mate :D
Total: $1484.43
Core2 Quad Q9400 @ 3.00GHz ✦  8GB Corsair RAM ✦Asus P5G41Tm - Lx3 ✦ Sapphire R9 270 Dual-X ✦ WD Caviar Green 640 GB ✦ Seagate Barracuda 160GB ✦ Fractal Design Define R5 ✦ 1Life ps:jet 700W ✦
Lenovo Y520 - GTX1050Ti - i77700k - 250GB Samsung M.2 NVME SSD  :D
https://linustechtips.com/topic/343345-building-first-pc/#findComment-4677237
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  (£198.71 @ Amazon UK)
Motherboard: Gigabyte GA-B85M-DS3H Micro ATX LGA1150 Motherboard  (£49.36 @ CCL Computers)
Video Card: Gigabyte GeForce GTX 980 4GB WINDFORCE Video Card  (£476.34 @ Aria PC)
Case: Corsair SPEC-03 White ATX Mid Tower Case  (£47.15 @ Aria PC)
Total: £955.92
Generated by PCPartPicker 2015-04-07 18:45 BST+0100
Same performace as a locked i7 for much less money.
https://linustechtips.com/topic/343345-building-first-pc/#findComment-4677294
Hi fellow mate :D
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  (D
Hey thanks for the reply
I changed it up a bit to get it closer to my price point
http://uk.pcpartpicker.com/p/gbjwZL
As I can always upgrade in the future, I also took off 150 of my initial budget for a monitor,keyboard and mouse
https://linustechtips.com/topic/343345-building-first-pc/#findComment-4677385
Hi fellow mate :D
Total: $1484.43
That build except change the motherboard to the MSI krait edition
CPU-i5 4690k 4.4ghz @ 1.190V, MOBO-MSI z97 gaming 3, Cooler-hyper 212 evo, GPU- r9 290x asus directcuII (-37Mv), Storage-120gb v300(switching soon), 1tb caviar blue, CASE-Red/black h440, PSU-Antec TPC 650.
https://linustechtips.com/topic/343345-building-first-pc/#findComment-4677387
