Crossfire help
Go to solution Solved by VolkA,
I got an xfx 290 and a tri-x 290. I heard the tri runs cooler than average so would it make more sense to run that card as the primary? Since it will take most of the load, it will be the cooler card?
Yup. In theory the primary card will take most of the workload so for your case, use the tri-x as the primary card.
Z77A-G43 LGA 1155, Intel I5 3450s, Radeon R9 290 (non-X), Cooler Master V750 Gold (750W) PSU, 2x4GB Ripjaws X 1866 MHz, 1x4 Crucial 1866 MHz, Samsung 840 Evo 500GB, Thor V2 Full-tower Case, Acer 1920x1080 Monitor
https://linustechtips.com/topic/342979-crossfire-help/
[CPU] i5-4690K @ 4.5GHz with NZXT Kraken X61 [MOBO] Asus Z97-AR [Memory] HyperX Fury 32GB DDR3-1600 [Storage] Samsung 840 EVO 500GB & WD 1TB Black & Hitachi 1TB [GPU] Gigabyte GTX 1080 8GB Xtreme Gaming [Case] Corsair Air 540 [PSU] Cooler Master V1000 [Case Fan] Corsair SP140 LED Fan x 3 & SP120 LED Fan x 3 [Display] Main: Philips 31.5" FULL HD IPS | Side: Philips 28" 4K UHD [Keyboard] Razer Blackwidow Ultimate Stealth Edition [Mouse] Razer Ouroboros [Mouse Pad] Razer Firefly [Sound] BOSE Companion 5 Multimedia Speaker System
https://linustechtips.com/topic/342979-crossfire-help/#findComment-4672526
