New Mid-Range Headphones: Help!
Solved by Dzzope,
AKG K553 For $120 on massdrop (RRP $299).. These aren't even released yet!!
Also Antlion Modmic 4.0 is $35, Thats right on your budget and a much better quality of sound than you'd get from a Headset.
The only criticism I've heard of the modmic is that it could do with some cable management but IMO you can just twist the 2 wires to keep them from being an annoyance.
Nebcs ·
FancyPants101 ·
l3eyond ·
1
Serendipity1344 ·
Posted in Graphics Cards5
