No, don't try it you will ruin your card
My Rig:  CPU: Core i7 4790K @4.8ghz  Motherboard: Asus Maximus Vii Hero  Ram: 4x4GB Corsair Vengeance Pro 2400mhz (Red)  Cooling: Corsair H105, 2x Corsair SP120 High Preformance Editions, Corsair AF 140 Quiet Edition  PSU: Corsair RM 850  GPU: EVGA GTX 980 SC ACX 2.0  Storage: Samsung 840 EVO 120GB, WD Blue 1TB  Case Corsair 760t (Black)  Keyboard: Razer Blackwidow Chroma  Mouse: Razer Deathadder Chroma  Headset: ATH-M50X Mic: Blue Yeti Blackout
That 4 pin plug is meant for the CPU power not the GPU, GPU's use a minimum of a 6 pin when they require external power. You need to buy a new PSU to support the GPU because it will not work without the proper plugs.
"The of and to a in is I that it for you was with on as have but be they"
before you tried another method by purchasing another molex to 8pin and 6pin  adapter, look at your PSU rail amps, well most likely it doesn't have enough power to light your card.
anyway you will need to get proper PSU for your new card
