Hi guys, for a couple of months, my CPU is running very high (45 to 65% at idle). The process using all the CPU is WMI Provider Host. I've already tried following a couple of tutorials online including a windows re-install and nothing worked. This is very frustrating because that when I'm using more CPU (ex: playing BF4), the CPU spikes to 98-100% which lags the game and sometimes even crashes it. Could someone possibly help me? Thanks a lot guys!
Setup:
motherboard: Asrock Z77 extreme
CPU: i5-3570k
GPU: GTX 760
RAM: 16gb
OS: Windows 8.1
BTW: Could someone please tag this guy, I dont know how to tag him on this post: TDP_equinox
Thanks again!
post-219828-0-91547800-1428034567_thumb.
https://linustechtips.com/topic/340371-wmi-provider-host-problem/
So I'm going to tell you basically what epicdude7623 told you to do, but with links.
First, remove any third party anti virus'.
Avast, AVG, Norton, Mcafee, etc. Get rid of it.
Second, download,and run all of these tools as an admin.
Adware-Removal-Tool
ADWCleaner
Combofix (doesn't run on windows 8.1 yet)
HitmanPro
JRT
MBAM
RogueKiller
SCC
Spybot
and TDSSKiller.
Now, my tools folder is a little out of date, so click yes to the updates on all of these, as you run them.
After this, reset all your browsers to default and remove any bad plugins.
Run CCleaner and reboot once more.
Do all your windows updates, and for good measure, open up an admin CMD prompt and type "SFC /Scannow" without quotes.
I7 4790K @4.5 Ghz 1.294V
VALIDATION, MSI Z97 Gaming 7, 24GB DDR3 1600, Asus Strix 1070 8GB OC@ 2.2Ghz, Corsair graphite series 760T (Black), Cooler master V850, NH-D15 w/LNA ,1TB Samsung 850 Evo,  480GB Sandisk Ultra II SSD, 3TB Seagate Barracuda x 3, 1 TB WD Passport (Backup drive), 2 TB WD Passport (Backup Drive 2),  Windows 10 Pro x64 (uhg), Logitech G900 Chaos (Main), Steelseries Rival (FADE) (Courtesy of Edzel Yago, Thanks Ed), Steelsieres Rival 300 Hyperbeast Special Edition, Coolermaster Quickfire TKL (MX Blue), Razer Blackwidow Tournament edition (Greens).  Audio: Sennheiser HD598 SE, Edifier S1000DB, AudioEngine D1 DAC; Yamaha MG06X Mixer & AudioTechnica AT2020.
Phones; Daily drivers: Nexus 6P 64GB/iPhone 6 (Music), Apple Watch, Apple AirPods.
Laptop: 2015 Macbook Pro 13, 8GB of RAM, 2.7Ghz i5, 240GB Apple SSD.
Plex Server: i7 3770, Gigabyte Board, 16GB DDR3 1600, Asus Strix GTX 1050ti 4GB, 120GB SSD Boot Drive, 8 x 3TB Seagate Barracuda, Rosewill RSV-R4000 With 2 Rosewill Hot Swap 4x Backplane Bays, 1050 Watt Corsair HX Series PSU,Hyper T2, Windows 10 Pro
I also do Youtube, check me out!
I've tryied all the programs epicdude sent me and none of them worked... I dont know if that's related, but I ONLY use google chrome as a browser and there are no tool bars or add-ons on it... I'll try the CCleaner!
Thanks
Dan
BTW: I've added a new screenshot on my first post showing wich process I need to suspend in order for my CPU usage to get back to 2-3%
Thanks
Dan
I would also suggest you run “System Maintenance”.
Follow these steps:
a.       Press “Windows key + W” from keyboard.
b.      Type “Troubleshooting” without quotes in the search box and hit enter
c.       From “Troubleshooting” windows click “View all” option from the left panel.
d.      In the list of options, click on “System maintenance”.
e.      Click “Next” and follow the on-screen instructions.
also try system mechanic to clean it up ;)
NO.
That is malware.
Sorry for the delay, but after trying all the software, nothing worked and I was kinda tired of installing all these things. I ended up formatting my C drive. Just had the trouble of having to re-install evrything, but now it's all fine! Ready for water cooling and OK soon!
Thanks a lot guys!
Dan
Thanks a lot guys!
Dan
NP.
Mark topic as solved pl0x
How do I do that?
At the bottom right of any post there is a "Mark Solved" option.
