need some advice
So should i get the CM v750 or one of these
http://www.skytech.lt/fdpsued1b750weu-fractal-design-psu-edison-750w-black-cord-p-213085.html
http://www.skytech.lt/gpm750c-psu-chieftec-navitas-psu-gpm750c-750w-p-168816.html
http://www.skytech.lt/bn202-psu-quiet-dark-power-pro-750w-80plus-gold-118-ock-p-125132.html
None of those PSUs are bad. Not even the Chieftec GPM-750C interestingly enough (CWT PUQ-G platform like the HXv2); however, it does uses lower quality caps than all of the others, and it is not as well priced as the V750 and Edison M - both of which are better than the Chieftec.
Anyways, since the CM v750 is priced so well, I would go for that over all of the other unit you are looking at.
The HX750i does offer full modularity, a much more relaxed fan profile (semi-passive design and the fan doesn't ramped up as high), a 7 year warranty (5 years on the V750), and Corsair Link features. The Corsair Link is more limited in comparison to the AXi, but it does allow you to monitor fan speed, power draw (how much it is drawing, outputting, the load and voltages of the 12/3.3/5v rails, and fan speed), and switch between single rail and multi-rail.
Unless you feel that those features are worth 65€ more, I would once again suggest the V750.
