Case Power Switch not responding
Go to solution Solved by Evan Owen,
take off the front panel of the zalman Z11.
-just yank really really hard while making sure to hold it with the other hand applying force in the opposite direction to keep from ripping the wires off.
check to make sure the two wires are connected.there should be a black and white and a black and green wire.
Thanks a lot, I pulled off the front panel to see what I was doing better and found the cable was plugged in upside down XD
I'm the end of a system build and the case (Zalman Z11) power switch is not working. I've triple checked all the connections to the motherboard and it won't respond. The motherboard is the new Gigabyte Z87X-D3H. If you can find a source to help me out or help me directly ASAP it would be great.
thanks
https://linustechtips.com/topic/33912-case-power-switch-not-responding/
thanks
Linus Sebastian said:
The stand is indeed made of metal but I wouldn't drive my car over a bridge made of it.
https://youtu.be/X5YXWqhL9ik?t=552
glad it got worked out.
