is there a way to down load pf sense off the website and run it as the main os and delete everything else  like steam os does
Yes? Put it on a USB stick or burn the ISO to a disk and install it.
2500K @ 4.5GHz | ASRock P67 Extreme 6 | 16GB Ram | GTX 750 Ti | 250gb SSD | 1TB+2TB HDD | 720W CoolerMaster PSU | Essense STX Sound Card | Define R5
https://linustechtips.com/topic/336721-pf-sense-help/#findComment-4594446
or do that but i dont have a usb stick or a cd handy
If you just want to have a look at it you could try it in a VM but you'll need a USB stick or CD/DVD to install it on a computer.
https://linustechtips.com/topic/336721-pf-sense-help/#findComment-4594469
