I have made two different build for a Gaming/Rendering/Recording PC, and I want to know which build would be better overall, one's more suited for rendering and ones more suited for gaming. I'm open to suggestions, tweaks, tips, and just good information about the parts I've chosen.
Rendering Suited:
http://ca.pcpartpicker.com/p/cQqwZL
Gaming Suited:
http://ca.pcpartpicker.com/p/GkNY7P
Recording what?
And if you aren't getting paid for it, you don't need X99.
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
The "gaming" oriented is the best allround. But if you are going to get dual monitors get two with the same size and resulution, looks waay better.
FX-8350 GTX760 16GB RAM 250GB SSD + 1TB HDD
"How many roads must a man walk down?" "42"
Recording games, you know, the stuff people usually record.
Z97 is the build for you.
It'll be better for you.
The i7 4790K is  more then enough to record gameplay, and with the 980 you can use shadowplay. It should probably not even be a problem streaming
I was gunna get two monitors and rotate one so it's in a different viewing mode, and have it as a vertical monitor next to my main monitor.
Ah, why would you want to do that? But sure it could work then.
Unless you're programming, there isn't really a point to portrait mode on monitors.
