So i only have 8gb left of my 120GB SSD somehow, but then i found this.
http://gyazo.com/239d9b461c9fcbb03a579b489d9d86b9
Should I firstly delete all but the newest restore point? Then should I more the system protection system to my 1TB HDD or does it have to be on my SSD. What space would you recommend to reserve for system protection? Thanks!
https://linustechtips.com/topic/335736-increasing-ssd-space-help/
You can go ahead and delete old restore points, and if your system is backing up to the ssd then configure it to backup to the hdd instead.
I'd say just reduce the system protection size, and I'm sure you could move it to the hdd if possible.
