Hi
So i have a HAF 932 case but i have recently went SLI with 2X 780s and now im having heat issues!
The cpu i7 4790k @ 4.7 has a H100i for cooling' about 55c - 60c under ful load but the top gpu gets to 80c really quick.
post-129393-0-27461600-1427385764_thumb.
I know its pulLing in hot air from the bottom card, but i cant move the bottom card into the 3rd slot as the psu is there and i cant move the psu to the top of the case because of the rad for the cpu.
I was looking at a custom water loop but not enough room for 2x 240 rads.
I also looked at the kraken g10 i think but same problam, no room for rads
I really like the case and dont want to change it, and ideas for modding it for more rads or any other ideas?
Bit long winded but thanks
https://linustechtips.com/topic/335714-modding-case-for-water-cooling/
suggestion:
take properly focused pictures with actual lighting so people can actually see where things are in the case :P
Project Hephaestus
Intel Core i5 6600K @ 4.2GHz~ASUS Maximus 9 Hero~32GB DDR4 @ 3200MHz~ZOTAC GTX 980 AMP Ed.
MUCH better lol
Hmm that case+mobo kinda fucks you in the mouth..aside from getting a thinner/slim PSU the only thing I can think to do is go to a custom water loop for your whole system and get a couple blocks for the cards. Mighty expensive but thats my .2cents
Project Hephaestus
