motherboard help
Go to solution Solved by Marcosoft,
The asrock seems to be better. I would cheap out on the motherboard and instead spend some more on other parts, gpu and ram specifically. There are many other cheaper options with the same chipset. Are those the only ones available?
If you told us your budget we could probably suggest a better combination
i im planning on building a new system with a amd athlon 2 x4 630and ive got it down to the asrock fm2a88x extreme 4+ or the asus m4a78t-e.
This is my first "gaming" build and this is what im thinking of using in the system;
corsair cx 430
amd athlon 2 x4 630 revison c2 95w
ati radeon hd 260xt 512mb ( smaller card for the fm2+ socket)
4x 1gb corsair ddr3 ram
650gb 3.5 sata drive
Can abody recomend which one might perfrom better
cheers
tom
https://linustechtips.com/topic/335700-motherboard-help/
corsair cx 430
cheers
tom
motherboards do not affect performance
https://linustechtips.com/topic/335700-motherboard-help/#findComment-4579783
https://linustechtips.com/topic/335700-motherboard-help/#findComment-4579958
