Can't Change Power Plan Minimum Processor State...
Can't seem to be able to change the Minimum Processor State in power options, the setting doesn't take effect.
Gaming PC: Case: NZXT Phantom 820 Black | PSU: XFX 750w PRO Black Edition 80Plus Gold (Platinum) | CPU: Intel Core i5 4690K | CPU Cooler: BE QUIET! Dark Rock Pro 2 | MB: ASUS Sabertooth Z97 Mark S | RAM: 24GB Kingston HyperX and Corsair Vengeance 1866MHz | GPU: MSI R9 280X 3G | SSD: Samsung 840 Evo 250GB | HDD: 9TB Total | Keyboard: K70 RGB Brown | Mouse: R.A.T MMO7
Laptop: HP Envy 15-j151sa | 1920x1080 60HZ LED | APU: AMD A10-5750M 2.5GHZ - 3.5GHZ | 8GB DDR3 1600mhz | GPU: AMD  HD 8650G + 8750M Dual Graphics | 1TB SSHD
Try a restart
Done that 3 times now :(
I have high performance set with min/maximum procesor state at 100% but my CPU reduces to 5%?
does it let you set 99%?
The changes set but it doesn't affect my CPU :/ I'm trying to fix the DPC problem in my other topic and nothing seems to work :/
