I'm pretty close to building my first computer and I wanted to overclock, would this motherboard be good for what I want? ( http://bit.ly/1mXM7vO) or should I get something better? I'm getting a budget system and looking for a mobo from $100 - $160. Any feedback would be appreciated. Build: http://pcpartpicker.com/p/dF74hM
https://linustechtips.com/topic/333669-motherboard-help/
How about this ASUS board http://www.newegg.com/Product/Product.aspx?Item=N82E16813131851 - it's about the same price. Otherwise, I'd recommend this http://www.newegg.com/Product/Product.aspx?Item=N82E16813131877 for a little more.
Giga-byte is okay, but UD3 boards leave much to be desired.
Good luck!
-Abe
-The Sausage King of Chicago
https://linustechtips.com/topic/333669-motherboard-help/#findComment-4570101
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($178.99 @ SuperBiiz)
Motherboard: ASRock H97M PRO4 Micro ATX LGA1150 Motherboard  ($73.98 @ Newegg)
Memory: Mushkin Silverline 8GB (2 x 4GB) DDR3-1600 Memory  ($54.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($49.98 @ NCIX US)
Video Card: XFX Radeon R9 280X 3GB Double Dissipation Video Card  ($199.99 @ Newegg)
Case: Corsair 300R ATX Mid Tower Case  ($59.99 @ NCIX US)
Power Supply: Rosewill Capstone 550W 80+ Gold Certified ATX Power Supply  ($39.99 @ Newegg)
Operating System: Microsoft Windows 8.1 (32/64-bit)  ($99.99 @ NCIX US)
Total: $757.90
Generated by PCPartPicker 2015-03-25 14:41 EDT-0400
i7 8700K , Z370 K6 FATAL1TY , GTX 1080Ti rog strix , NOCTUA NH-D15S ,
2x16gb DDR4 3200MHz/cl16 , FRACTAL R5 window , EVGA G3 750w gold ,
480gb m.2 NVMe WD SN350 + 500gb SAMSUNG EVO 850 ,
creative sound blasterX AE-5 Plus , MSI Optix G241 , WINDOWS 10 PRO
https://linustechtips.com/topic/333669-motherboard-help/#findComment-4570194
Total: $757.90
Agreed.  This build is a better value.  The only concern I have is the AsRock motherboard.. they never work out for me.  However, there is enough margin built in (compared to OP's first build) that a substitute could easily be found w/in budget.
https://linustechtips.com/topic/333669-motherboard-help/#findComment-4570354
i have quite the opposite experience with them .
now i have third asrock board in the row
(first was AM3 , then 1155 low end board and now Z97 anniversary)
and they have never let me down so far .
although of course he can easily get more "shiny" motherboard within his budget :
for example H97 asus pro gamer , or even MSI Z97 krait (possibility of future upgrade to "K" cpu and overclocking) for like a 105 bucks
https://linustechtips.com/topic/333669-motherboard-help/#findComment-4570479
i5 4460 + stock cooler + cheap H97 or even more expensive H97/Z97 motherboard has actually same or lower price ,
consumes less power and it will give you better performance in gaming and most other tasks .
number of cores and clock speeds are meaningless in this case .
https://linustechtips.com/topic/333669-motherboard-help/#findComment-4570686
