Ssd and harddrive required
Solved by Captain_WD,
I want a good ssd, i have a budget of 75$ . What is the best ssd for that kind of money? i will put the OS and every program on it. but anything game-related even steam would be on the hard drive. I have no specific budget for the hard drive. i want it a 1-2 tb hard drive. But the ssd has to be capped at 75$.
and is the kingston v300 any good? also the adata xpg ssd, is it good or not?
Hey amr sameh,
Pretty much any SSD would give you great speeds for regular consumer usage. I would check out reviews and comments about the different brands and models to see which one has the best reputation within your price range.
Regarding the HDD, games rely on storage only for their loading times. FPS and graphis would be the same with pretty much any drive. I would suggest checking out WD Blue and WD Black for good and reliable performance. Here are some links:
Captain_WD.
