so, recently switched to a new Internet provider and the new package comes with TV, in order to get the most out of the TV(in the loungeroom) it needs to be connected via ethernet cable to the router however i also need to connect my computer and rather than either having a very long cable or using wireless i'd prefer the router next to my computer, i keep reading about bridges or repeaters and things however im literally at the point of smashing my face repeatedly into my table, im either a complete idiot or it is amazingly difficult to do something which sounds amazingly simple.
so, as if you were talking to a complete idiot; can i have the router in my room and a second one in the lounge to pick up the wifi and allow me to plug a cable from it to the tv box?
https://linustechtips.com/topic/32866-need-help-creating-a-bridgerepeater/
With wifi repeaters you really need to have them connected via ethernet cable. Try running it under the floor/carpet or just generally out of the way.
CPU: i5 4670k • Cooler: Corsair H100i • Motherboard: MSI Z87 MPOWER • RAM: Crucial Ballistix Elite 2x 8GB • Storage: Samsung 840 250GB SSD, 2x WD Red 3TB • GPU: EVGA GTX 780 3GB • PSU: Corsair RM750W • Case: Corsair 750D • Mouse: Razer Naga 2012 (I actually use the thing for productivity/media buttons) • Keyboard: Ducky Shine 3 w/ Browns - Green LED • Monitor: Asus PB278Q 27" 2560 x 1440, ASUS PB238Q 23" 1920x1080 • Lighting: 2m NZXT Sleeved Blue LED Strip • pcpartpicker.com/p/3cHfZ
get a power line adapter. it transmit internet through your electrical wires at 200 or 500 mbs
You can then get an ethernet cable out at the end, there are some models that also act as an access point.
If you have a useless router it is possible to configure it as an access point for your other router but it will still require a cable between them. (I could explain how to if you want)
If you want a reapeter, buy a product labelled as a repeater because it is relatively hard to transform a normal router into one.
(It involves custom firmware flashing (dd wrt and the like) that I wouldn t recommend you to do)
bottom line, the easiest thign to do is to buy a powerline kit
for example this:
http://www.ncix.ca/products/?sku=81383&vpn=TPL-407E2K&manufacture=TRENDnet&promoid=1213
it take no config at all and all you need to do is plug 2 wires and 2 adapters.
Anything I write is just a comment, take is as such, there is no guarantees associated with anything I say.
ATX Portable rig (smaller than prodigy(LOL)) :  Nmedia 2800 | Gigabyte Z77x-ud3h  | Corsair HX1000 | Scythe Big Shuriken | i5 3570K  |  XFX R9 290 DoubleD | Corsair Vengeance 32GB
