Does RAM speed affect CPU overclocking speed?
Go to solution Solved by runit3,
If you are using the XMP profiles designed for your RAM, no.
If you are tightening timings, or overclocking outside of an XMP (even underclocking) profile it will likely give you instability, which would throw your OC. The BSOD codes, should they show up, will be indicitive of what failed. Ex. 01A is a common RAM OC fail code. 024 and 101 are common CPU OC fail codes (usually related to voltage).
The failure points of the OC would be separate. I've never OC'd my RAM and had it throw a 024 when the CPU OC is solid.
Hi everyone,
This is probably a silly question but does having a high RAM speed affect how high a CPU would overclock and vice versa? And what scenarios would having a high RAM speed would be best? Any opinions is greatly appreciated!
Current System Setup | Case: Corsair Obsidian 650D | CPU: Intel Core i7-4790K @4.0GHz | CPU Cooler: Corsair H100i Hydro Series | Motherboard: MSI Z97 Gaming 5 | RAM: Corsair Vengeance 1600Mhz 8GB (2x4GB) | Graphics Card: MSI Radeon R9 290X | SSD: Samsung EVO 840 250GB | HDD: Western Digital Blue 1TB 7200rpm | PSU: Corsair HX750W 80+ Gold | Display: Dell UltraSharp 24" U2414H | Headset: Tritton Kunai | Mouse: EtekCity Scroll X1 | Keyboard: Microsoft SideWinder X4 RED LED
https://linustechtips.com/topic/327397-does-ram-speed-affect-cpu-overclocking-speed/
Overclocking your RAM a lot puts extra strain on the CPU's integrated memory controller. This can make high CPU overclocks unstable.
High RAM speed is good for some workstation applications like 3D modeling and HD video editing.
LanSyndicate Build | i5-6600k | ASRock OC Formula | G.Skill 3600MHz | Samsung 850 Evo | MSI R9-290X 8GB Alphacool Block | Enthoo Pro M | XTR Pro 750w | Custom Loop |
Daily | 5960X | X99 Sabertooth | G.Skill 3000MHz | 750 NVMe | 850 Evo | x2 WD Se 2TB | x2 Seagate 3TB | Sapphire R9-290X 8GB | Enthoo Primo | EVGA 1000G2 | Custom Loop |
Game Box | 4690K | Z97i-Plus | G.Skill 2400MHz | x2 840 Evo | GTX 970 shorty | Corsair 250D modded with H105 | EVGA 650w B2 |
