Your topic was probably removed for some reason. Ask a mod.
https://linustechtips.com/topic/326299-problem-with-the-forum/#findComment-4432020
Did you activate your account via E-mail?
CPU: Intel i7-8700k 5GHz @ 1.35v | Cooling: EK Predator 360 | MotherBoard: ASUS z370-E | RAM: G.Skill Ripjaws V 32gb 3200MHz (4 x 8GB) | GPU: ASUS GTX 1080 TI OC
Case: Rosewill Blackhawk Ultra Modded side panel | SSD: Samsung 512gb 960 Pro | HDDS: 3TB Segate 7200rpm / 4TB HGST 7200rpm | PSU: EVGA G3 1000w | Display:ASUS VG248QE 24" / HP 25" 2511x / SAMSUNG 35" TV
Ex HDD: 3TB WD MyBook USB 3.0 | Keyboard: Rosewill MX Blue / Corsair K70 Red | Mouse: Logitech G602 | OS: Windows 10 64-bit Home Premium
https://linustechtips.com/topic/326299-problem-with-the-forum/#findComment-4432029
Yep otherwise how could I access the forum?
truuu
https://linustechtips.com/topic/326299-problem-with-the-forum/#findComment-4432036
I am new sorry!
Can you tell me how to contact a moderator?
On the bottom of the front page there's a bunch of usernames, the green ones are mods. Click on it and message them :)
https://linustechtips.com/topic/326299-problem-with-the-forum/#findComment-4432056
